I created an App Script Token with Computer & Contacts -> View Entries permissions, and then I go to the webapi.teamviewer.com website to test the API and I am getting the "Bearer token missing." error
For steps, I copied my token created under the App Script piece, pasted it into the Bearer Token heading at the top of the webapi test page and hit Explore. Then I copied a TeamViewer ID from one of the computers I have access to and hit Try now! and it returned the following response
"error": "invalid_token",
"error_description": "Bearer token missing.",
"error_code": 2
Am I creating the wrong type of App token? Or do I need to have additional permissions other than just View Entries? Any advice is appreciated, thank you!
