Download MSI files from Teamviewer Management Console
Hey. I am pretty newbie in this field, but i really want to learn and give it a try.
I am trying to make a script that automaticly download the latest version from TeamViewer from Management Console. I understand i have to use Teamviewers WebApi and create a token, but what now? I thought it was really easy, maybe it was a archive anywhere, but no. Does anybody have a clue in this field? If so, i would really appreciate it.
  • jonearthur
    jonearthur Posts: 1
    The Download file for the MSI package can be found inside the Management Console. Under Design & Deploy --> Edit your customized Host --> the Download MSI link is displayed in the lower right corner.
    It is helpfull or not
  • mariusthomassen
    mariusthomassen Posts: 2 ✭✭
    Hey.
    Thanks, it works, kinda. If i click the "+", the relevent options for me are "Host" and "Full Client". But when i find the download link to the MSI, both shows x32 bit, where are x64? If that made sense.
    Extra question:
    And are the MSI link perment and automatically updating to the newst?
    Thanks again
