Account assignment popup after silent installation of Customised Teamviewer Host
Arioso
Arioso Posts: 1
Hello all,
I have created a custom Host Module with our corporate logo and text to deploy to our 1k+ windows laptop fleet, i chose to download the deployment package which has given me a Teamviewer_Host_Setup.exe, which installs perfectly with the /S switch to run silently, apart from that it pops up a confirmation box called Account Assignment with a button called Allow and Finish that needs to be clicked to complete the install and add the computer to a group.
Please see attached photo of the popup and install command.
Is there a switch or some reg settings we can use to prevent this popup? Deployment of the software needs to be completely silent.
Thanks in advance.
  • tas7330
    tas7330 Posts: 1
  • Marcus_B
    Marcus_B Posts: 1
    still no updates ?
    facing the same problem
  • Tony750
    Tony750 Posts: 8 ✭✭
    up ?
  • VlictSupport
    VlictSupport Posts: 2 ✭✭
    Having the same issue
  • nate303
    nate303 Posts: 3 ✭✭
    PLEASE make an option to silent through this prompt, its killing my deployment - im going to have to revert back and now i cant take advantage of auto assigning into device groups, and everything that comes with it.
    it even has in the management " A device rolled out with this configuration will automatically be associated with the company" - there HAS to be a way to silent around this prompt, is this something we will see in the future or do i have to rebuild my deployment? (please dont be the latter)
  • nate303
    nate303 Posts: 3 ✭✭
    any updates on this? its really killing my asset management and im having a heck of a time deploying this across 400+ users across the country.
  • Harmen1966
    Harmen1966 Posts: 1
    I'm using this parameters with the created msi but it was a **bleep** of a job to figured this out;
    start /wait MSIEXEC.EXE /i "TeamViewer_Host.msi" /qn DESKTOPSHORTCUTS=0 CUSTOMCONFIGID=xxxxxxx APITOKEN=yourapitokenhere ASSIGNMENTOPTIONS="--alias %COMPUTERNAME%"
    The installation is complete silent with no popup screens at all.
This Week's Leaders
