Operating system: Linux
Version: 15.46.5
Release date: 2023-09-26
The problem is solved since yesterday.
I have raised TV ticket 44330464 for the ctrl+c issue. They have confirmed the regression, and said a fix is scheduled for version 15.48
Hi, thanks to TV support we temporarily solved by downgrading (and purge) to version 15.45.3 on both linux and windows.
Error does not occur with Windows host version 14.x
Same happening for me since a couple of weeks. From Ubuntu 20 to Windows 10. Ctrl+C does not work, normal Copy actions via mouse do work. Ctrl+X does work. Some other hotkeys I use for certain applications like Ctrl+Shift+C does not work either.
I have made a workaround by using AutoHotkey to make Ctrl+X map to Ctrl+C, but this is not ideal.
Same problem happening here too, connecting from Linux to Windows. This applies not only to ctrl+c but also e.g. ctrl+h, probably all control characters are affected.
Please fix this regression as soon as possible, it is a major problem.
For ctrl+c one can use the workaround ctrl+insert on Windows, but the other control characters don't have such a workaround.
Same identical problem here, from linux client to windows host: Ctrl+c stopped working in all applications.
An urgent correction is needed.
PS: attached image of notepad++
Ctrl+C stopped working for me from any Linux client to any Windows host. Checking the input in Notepad++, I always get the Character "ETX" which is probably the same as SIGINT (Ctrl+C in Terminals).
I don't know which update broke it. There's a chance it broke due to the update of the Windows client, because I remember I had 2 sessions and during my work in the one session Ctrl+C stopped working as on the other session it still worked. The next day it stopped working on the other machine es well.
BUT: It works with Windows client to Windows host.
I'm pretty sure it stopped working on September 27th or September 26th.
EDIT: Copy feature works from Linux client to Linux Host.
