14567810»
  • Theoxis
    Theoxis Posts: 1
    (1) I installed the TeamViewer app on my Synology
    (2) I assigned the TeamViewer app on my Synology successfully to my account
    (3) When I enable 'Remote Terminal' and I connect, I successfully get to see the Synology interface. I can log in etc, all works totally fine.
    (4) When I disable 'Remote Terminal' and I connect, nothing happens. I don't get a screen with the Synology interface or anything. The desktop app says: The session with <nasname> has been terminated (0:00).
    A window is supposed to open right? I don't know how to troubleshoot this. Thank you for any help!
    (I tried restarting the app on the synology btw, that didn't help)...
  • AndersMogensen
    It would be nice to have Teamviewer updated to the new grouping system :-)
  • ARTIM
    ARTIM Posts: 2 ✭✭
    Hello
    I have 3 synology and only 2 can be with automatic login with our account.. The third ask for the password written in the teamviewer dialog on synology item...
    I tried to remove and re install but no success. it doesn't depend on wich synology it is, the tird one is always in a manual state like connexcting..
    2 synology's are the maximum we can add as automatique connection (easy access) ?
    thanks for your time
  • AramKalantaryan
    AramKalantaryan Posts: 1 Staff member 🤠
    @ARTIM free licenses support up to 2 endpoint. Over this you need to buy a license.
