what should the User name look like?
Hello!
The username in TeamViewer typically has some specific requirements. Here are a few tips to ensure it gets accepted:
1. Length: Make sure your username meets the minimum and maximum character length (usually between 3-15 characters).
2. Characters Allowed: Stick to alphanumeric characters (letters and numbers). Avoid special symbols like @ ,
, etc., unless explicitly allowed.3. Uniqueness: The username should be unique. If someone else is already using the name you’re trying, you’ll need to tweak it by adding numbers or variations (e.g.,
JohnDoe123
).4. Avoid Spaces: Use underscores
_
instead of spaces if you need to separate words.If none of these tips work, it could be a glitch. Try clearing your browser cache or using a different browser/device, and ensure the TeamViewer software is up to date. Let me know if you still face issues!
