Teamviewer 12 for Raspberry Pi
I have a Teamviewer 12 liscence and don't want to upgrade to 13. Unfortunately, I can only find a v13 for Linux Teamviewer Host for Raspbian. This means the only way I can remote into it is via iOS, since I can't update my PCs to v13. Does v12 not exist for Linux Teamviewer Host for Rasbian?
  • Hi @TampaLegalCopie,
    Thanks for posting.
    TeamViewer IoT agent is supported only for TeamViewer v13 unfortunately.
  • I have ran in to a similar issue,
    I have had teamview 12 host installed on my 3 Raspberry pie's
    I am no longer able to access the one I had to run an sudo apt-get update upgrade on.
    Since it got the newest version 13 on the updgrade. I would need to downgrade to version 12 again is that impossible?
  • Here is the link to the version 12 for raspberry (armhf)
    Open up your teminal as root
    wget http://download.teamviewer.com/download/linux/version_11x/teamviewer-host_armhf.deb
    apt update
    apt install ./teamviewer-host_armhf.deb
    Or you can even do by this way once downloaded the package using wget
    dpkg -t teamviewer-host_armhf.deb
    apt-get install .-f
    If you need, you can download the Teamviewer 12 version for your PC, you know, actually it's the stablest
    wget https://dl.tvcdn.de/download/version_12x/teamviewer_12.0.90041_i386.deb
    dpkg --add-architecture i386
    apt update
    apt install ./teamviewer_12.0.90041_i386.deb
    dpkg -i teamviewer_12.0.90041_i386.deb
    apt install -f
    Hope this helped , Enjoy yourself
