Import user Or integrate with Active director
Hi Expert,
I am new to teamviewer and we just bought corporate license, I checked it can import all users from excel file or also can integrate with AD, has anyone used those function, which is easier and stable. I have less than 400 users, can someone share some idea about this?
What we need is remote access for the pc and have message chat with company users
Shermaine
  • Good Post :)
    Wanted to mention that since we have an open API. Users can edit the script to accommodate nested OUs.
    $syncGroupCN = "tvuser"
    $syncGroupOU = "myUsers"
    $syncGroupSearchFilter = "(&(objectCategory=user)(memberOf=cn=$syncGroupCN,ou=$syncGroupOU,ou=anotherOU,ou=anotherOU2,$dn))"
    When editing the scripts for nested OUs. It should always start from the bottom OU to the top level OU.
  • Thanks, Tobias.
    I am going to import the user, rather than integrate with AD, anyway AD does not support Single Sign on now, I would rather doing import from CSV file.
    I am thinkin g if it is possible to import the photo as well, for each user profiler.
  • thanks you as well, Alfonso588.
  • scharman
    scharman Posts: 2
    whats the exact sytax of the start -sleep ?
  • haribn
    haribn Posts: 1
    I ran the script with our domain parameters and it ran successfully.  But what is the next step after running the script?  I did not see anu output.
  • Helllo Tobias the helpful one. I have a question regarding your ADSync script and AD integration in general. First question is, if I am running this script in the PS ISE, where will I see the outcome? Second question is I am running into an error having to do with line 146. The error reads
    Reading AD OU members
    Get all users...
    Request [GET] /api/v1/users?full_list=true
    Request failed! The error was 'The remote server returned an error: (401) Unauthorized.'.
    Received content was:
    {"error":"invalid_token","error_description":"Access token does not have the required permissions for this function.","error_code":2}
    Exception calling "Add" with "2" argument(s): "Key cannot be null.
    Parameter name: key"
    At C:\Users\owood\Downloads\TeamViewer_API_Example_Active_Directory\TeamViewer_API_Example_Active_Directory\PowerShell\ADSync.ps1:174 char:3
    + $dictUsersAPI.Add($u.id, $u)
    + CategoryInfo : NotSpecified: (:) [], MethodInvocationException
    + FullyQualifiedErrorId : ArgumentNullException
    AD OU Sync finished.
    I am no PS guru and do appreciate the help (and Maricela's and Christian's). Can you shine light on what is going wrong? Quick side note, I used the Unblocked-File cmdlet instead of figuring out the right execution level and unblocked files that were blocked.
Howdy, Stranger!
