Assignment API issue
So, recently I made an automated wrapper for TeamViewer installation via SCCM. Largely, this deployment is successful and works as intended.
However, I have several machines that are failing to assign due to this error:
2018-01-30 10:28:37 WebAPI: POST 'devices/assign' (Body: {"device_id":"d344428968","assign_mode":"easyrollout","current_device_password":"REDACTED","enable_easy_access":true})
2018-01-30 10:28:40 => 400 (Body: {"error":"failed_to_assign_manager_to_device","error_description":"FailedToAssignManagerToDevice","error_code":17})
2018-01-30 10:28:40 => Assignment failed with:
POST-Request 'devices/assign' failed with 400 (API-Error: 'failed_to_assign_manager_to_device' (Code 17), Description: 'FailedToAssignManagerToDevice')
This same exact script works for 180 other machines as well as new images. Re-launching the deployment does not resolve. What password is the API trying to use here? What exactly is current_device_password?
One more thing; is there a way to manage endpoints as a centralized list rather than shared lists that all have to be updated individually? Having some issues with that as the whole point of this deployment was to completely reinstall a specific version of TV with unified policy; to do that they had to be re-assigned, and to do that I deleted them all from the web console.. but the contacts still exist on other account lists. Is there no centralized management of endpoint lists?
Did you manage to fix this?
Did you manage to get a solution to this? Facing the same issue...
I struggled with this for hours. The problem in my case was that I was granting easy access with a group id, but I was not an owner of the group that was getting assigned. I removed the group-id setting and it assigned flawlessly. I then made a separate API call to assign the device to the appropriate group.
Here is the command I was using that didnt work:
teamviewer.exe assign --api-token=[token redacted] --grant-easy-access --alias "TestAlias" --group-id g175917987 --proxy 127.0.0.1:8888
The command that worked:
teamviewer.exe assign --api-token=[token redacted] --grant-easy-access --alias "TestAlias" --proxy 127.0.0.1:8888
I removed the proxy after I was done debugging.
Hope this is helpful
