Are you working with Insider Builds❓
Participate in our survey and get to know the new UI 👉 here 👈.
Teamviewer AD integration: user creation does not work
I tried to use the Powershell script for user creation.
I succeed in connecting to AD and teamviewer using the API access token. My users assigned to the teamviewer security group are found, but I don't get them created in the teamviewer account portal.
Here is my script output:
Starting AD OU Sync...
Ping API...
Request [GET] /api/v1/ping
200 OK
Ping: Token is valid
Reading AD OU members
Get all users...
Request [GET] /api/v1/users?full_list=true
200 OK
Request ok!
Get single user by mail ([email protected])...
Request [GET] /api/v1/[email protected]&full_list=true
200 OK
Request ok!
No user with email= [email protected] found.
CreateUser: [email protected] with this values:
200 OK
Request ok!
AD OU Sync finished.
I use this script:
# Configuration
# API access token
$accessToken = "xxxxxxx-xxxxxxxxxxxxxxxxxxxxx" #<-- your access token, can be left empty when OAuth (below) is configured.
# OAuth: API client id & authorizationCode
# if all variables are set here, OAuth will be used to request an access token
$clientId = "" #<-- Create an app in your TeamViewer Management Console and insert the client ID here.
$clientSecret = "" #<-- Insert your client secret here.
$authorizationCode = "" #<-- Visit https://webapi.teamviewer.com/api/v1/oauth2/authorize?response_type=code&client_id=YOURCLIENTIDHERE
# Login, grant the permissions (popup) and put the code shown in the authorizationCode variable here
# domain settings
$dn = "dc=domain,dc=com"
# ldap settings
$dcIP = "10.1.1.1"
$dcLdapPort = "389"
# user group to sync with management console
$syncGroupCN = "SG-Teamviewer-Users"
$syncGroupOU = "General Groups,ou=Security Groups"
#$syncGroupSearchFilter = "(&(objectCategory=user)(memberOf=cn=$syncGroupCN,ou=$syncGroupOU,$dn))"
# new user defaults (if not available in csv import file)
$defaultUserLanguage = "en"
$defaultUserPassword = "myInitalPassword!"
$defaultUserPermissions = "ShareOwnGroups,EditConnections,EditFullProfile,ViewOwnConnections"
# deactivate company users not found in the configured AD group
$deactivateUnknownUsers = $false
# testRun needs to be set to false for the script to perform actual changes
$testRun = $true
# includes
$currentPath = Split-Path ((Get-Variable MyInvocation -Scope 0).Value).MyCommand.Path
. (Join-Path $currentPath "Common.ps1")
# Functions
# Returns the AD members of the configured usergroup from above
function GetADMembersOfOU()
Write-Host
Write-Host "Reading AD OU members"
$result2 = $NULL
try
$domain = "LDAP://" + $dcip + ":" + $dcLdapPort + "/$dn"
$root = New-Object System.DirectoryServices.DirectoryEntry $domain
$query = new-Object System.DirectoryServices.DirectorySearcher
$query.searchroot = $root
$query.Filter = $syncGroupSearchFilter
#needed user properties
$colProplist = "name", "mail", "givenName", "sn", "department", "description", "userAccountControl"
foreach ($i in $colPropList)
[void]$query.PropertiesToLoad.Add($i)
$result2 = $query.findall()
$userDict = @{}
foreach ($objResult in $result2)
$user = @{}
$user["email"] = [string]$objResult.Properties.mail
$user["name"] = [string]($objResult.Properties.givenname + $objResult.Properties.sn)
#check user account status (00000000000000000000000000000010 binary, 2 decimal, UF_ACCOUNT_DISABLE)
$uacVal = $objResult.Properties.useraccountcontrol.Item(0)
$userEnabled = (($uacVal -BAND 2) -eq 0)
#skip user when required fields are missing, or account is disabled
if($user.email.length -gt 0 -and $user.name.length -gt 0 -and $userEnabled -eq $true)
$userDict.Add([PSCustomObject]$user.email, [PSCustomObject]$user)
else
Write-Host "AD user is missing name and/or email. Skipped."
$result2 = $userDict
catch [Exception]
Write-Host ("AD read failed! The error was '{0}'." -f $_)
$result2 = $NULL
return $result2
# Sync AD Usergroup with TeamViewer API
if($testRun -eq $true)
Write-Host "testRun is set to true. Information in your TeamViewer account will not be modified. Instead, all changes that would be made are displayed on the console. Press any key to continue..."
$x = $host.UI.RawUI.ReadKey("NoEcho,IncludeKeyDown")
Write-Host ("Starting AD OU Sync...")
# check OAuth requirements
if ($clientId -and $authorizationCode)
#get token
$token = RequestOAuthAccessToken $clientId $clientSecret $authorizationCode
if ($token){
$accessToken = $token
#ping API to check connection and token
if (PingAPI($accessToken) -eq $true)
#read users from the AD OU
$dictUsersAD = GetADMembersOfOU
#get all current users of our company from the API
$arrUsersAPI = GetAllUsersAPI $accessToken
#put all current API users in a dictionary, id field as key
$dictUsersAPI = @{}
foreach ($u in $arrUsersAPI)
#Write-Host $u.id
$dictUsersAPI.Add($u.id, $u)
#sync
#for each user in AD group: check against API if user exists (by mail)
foreach($usrKey in $($dictUsersAD.keys))
#Write-Host $usrKey
$userApi = $null
$userAD = $null
$userAD = $dictUsersAD[$usrKey]
$userApi = GetUserByMail $accessToken $usrKey #lookup API user by mail
if($userApi) #user found -> update user
Write-Host
Write-Host "User with email=" $usrKey " found."
if ($testRun -eq $true)
Write-Host "UpdateUser: " $usrKey " with this values:"
$userAD | Foreach-Object {
Write-Host $_.Key " = " $_.Value
Write-Host
$dictUsersAPI.Remove($userApi.id)
else
#Update the user
UpdateUser $accessToken $userApi.id $userAD
#remove this user from our dictionary
else #no user found -> create user
Write-Host
Write-Host "No user with email=" $usrKey " found."
Write-Host "CreateUser: " $usrKey " with this values:"
Write-Host
else
#Create User
CreateUser $accessToken $userAD $defaultUserPermissions $defaultUserLanguage $defaultUserPassword
# if configured, delete all users not in AD group
if ($deactivateUnknownUsers -eq $true)
Write-Host "Deactivate Unknown Users:"
#$dictUsersAPI.GetEnumerator() | Foreach-Object {
# Write-Host "DeactivateUser: id = " $_.Key " name = " $_.Value["name"]
foreach( $id in $($dictUsersAPI.Values))
Write-Host "DeactivateUser: id = " $id.id " name: " $id.name
Write-Host
else
#all users remaining in dictUsersAPI dictionary are not present in the AD group an can be deactivated
foreach( $id in $($dictUsersAPI.Keys))
DeactivateUser $accessToken $id
else
Write-Host ("No data imported. Token or connection problem.")
Write-Host ("AD OU Sync finished.")
  • Hi,
    I'm receiving the same errors.
    domain.local -> OU = tvusers -> security group 'tvusers' -> 2 regular domain users are members
    In AD snap-in we can look for the email-adresses and it finds them.
    Does this script still supposed to work?
  • Hi Stephan72,
    please give our new Active Directory Connector (AD Connector) a try.
    Team Lead Product Development (Enterprise)
    Did my reply answer your question? To help others, please accept it as solution. Thanks!
  • Hey!
    Thanks for the quick response.
    It's working almost perfectly.
    Just one thing: It seems to have trouble with users having German characters (ä,ö,ß) in their names. It fails to create those.
  • Hi Stephan72,
    thanks for the feedback.
    In which AD fields you are having the Umlauts?
    Did you get an error message, if yes, what?
  • Both Firstname, Lastname (givenName, sn) and Displayname
    Error: 2018-04-13 13:31:48 Creating user [email protected]
    2018-04-13 13:31:48 Failed to create TeamViewer user [email protected]: @{error=invalid_request; error_description=Unable to translate bytes [F6] at index 98 from specified code page to
    Unicode.; error_code=1}
    values of bytes and index  are different for the other users
  • Hello,
    thanks for the details, we will look into it.
  • carlos2
    carlos2 Posts: 1
    Hi there,
    for my end I am stuck with this PingAPI, it keeps telling me:
    "Starting CSV export...
    PingAPI : The term 'PingAPI' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was
    included, verify that the path is correct and try again."
    Does someone knows how to solve this ?
    Best
  • stephan72
    stephan72 Posts: 5
    Cool. Thx :)
  • Hello,
    we released :smileyhappy: a new version of our Active Directory Connector, please download the latest version and try it again.
  • Hello,
    We used it in test mode and it seems to be working fine now.
