How can we convert .blz files in .mp4 for example ?
How to share in Youtube ?
Dear Michael,
If you would like to convert a meeting you can do so by opening your recording and once you open it on the top you will see the option "convert". Choose this option and you can choose the path where it will be saved as well as the resolution. Once it's done your file will be converted to AVI format.
Let us know if you have any further questions.
Cheers -
Jaquie
Thank you so much... was trying for sometime now
the https://tvstomp4.com is not a solution but a workaround for the mac client!!!
Teamviewer needs to fix the Mac Client so the files can be converted into another format and users don't have to pay for 3rd party solutions just to get it in a playable format for others.
Hi!
Just to clarify, Mac version of Blizz does not have Convert-feature.
On those cases you can use online service https://tvstomp4.com to convert the file.
Hello @Vaiz1982,
The Convert button can be found when you open your .blz file and you will see the option on the top:
The file is usuallly converted to .avi- You will find further information in regards to the codecs in this thread.
Have a good Monday.
I can't find where the bottom to conver? Its the video -there is no any bototom like conver!!
Thank you for this information.
Now i can convert my videos
Good Afternoon,
Today there has been a fix released in regards to the Meeting Conversion bug. Please make sure that you have the latest version of Blizz. You can update your Blizz Version directly on the Blizz Options > About Blizz > and click on > Check for New Version.
Cheers,
Dear @jqvcog,
If you are not seeing additional codecs, these can be downloaded (if you are using windows) we kindly ask you to contact your IT Administrator for further assistance on this.
In case there's a different feature that you are not seeing, please provide us with further information.
I'm not seeing this on my recordings. Am I not seeing something?
Dear Morais,Thank you for the question.The issue with the convert functionality is a known bug since the last update.Blizz development Team is working to fix it soon with the coming update.We will inform you as soon as the issue is solved. We apologize for any inconvenience caused.If you have any further questions about Blizz, please feel free to contact us again.Joel Malemo
When I click on Convert Button nothing is happening, what's wrong?
Right, AVI container is used.
Regarding video codecs, session converter uses video codecs installed in a system (for Windows). So you can install additional video codecs and use them.
Hi @muntz,
As stated above it will be converted to .avi format.
If you would like to convert it to .mp4 format you will need to use an additional software.
Have a nice weekend!
what specific formats can you convert to?
...any answer?
