AD Connector issue
I am trying to set up the AD Connector but i get and error message either by running the bat file or the Invoke-Configuration.ps1 file.
The bat file closes itself and nothing happens.
When i try to run it from the powershell ISE :
Configure TeamViewer AD Connector.bat : AuthorizationManager check failed.
At line : 1 Caractère : 2
+ & <<<< '.\Configure TeamViewer AD Connector.bat'
+ CategoryInfo : NotSpecified: (Échec de la vér...izationManager.:String) [], RemoteException
+ FullyQualifiedErrorId : NativeCommandError
At line : 1 Caractère : 52
+ & {.\TeamViewerADConnector\Invoke-Configuration.ps1 <<<< ; exit $LastExitCod
e }
+ CategoryInfo : NotSpecified: (:) [], PSSecurityException
+ FullyQualifiedErrorId : RuntimeException
When running the PS1 file i get this :
Impossible to link argument to parameter « Path », because it has a Null value.
In \TMV\TeamViewerADConnector\Invoke-Configuration.ps1 : 28 Caracter : 36
+ $ConfigurationFile = (Join-Path <<<< $PSScriptRoot "TeamViewerADConnector.config.json"),
+ CategoryInfo : InvalidData: (:) [Join-Path], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : ParameterArgumentValidationErrorNullNotAllowed,Microsoft.PowerShell.Commands.JoinPathCommand
My ISE is in french so i have somewhat translated in english, i put the modified text in Italic.
Same problem here.
The exact error in English is:Join-Path : Cannot bind argument to parameter 'Path' because it is null.
At C:\Users\Tomas\Desktop\TeamViewer_AD_Connector\TeamViewerADConnector\Invoke-Configuration.ps1:28 char:36
+ $ConfigurationFile = (Join-Path <<<< $PSScriptRoot "TeamViewerADConnector.config.json"),0
