Teamviewer API : Urgent help required
flexinv
- Are the APIs available on local Host?
- Is it possible to start the Android app automatically at the boot up?
- Are there APIs to establish the remote connection to users without no user intervention?
- Is it possible to have the static session code for the connection?
- IS it possible to completely eliminate the team viewer GUI using APIs?
- Is it possible to connect or reconnect to the session after a disconnection?
- Is it possible to stay conncted to atleast 2 users at a time and switvh between them using team viewer APIs in run-time?
- Are the same APIs avaible for Android and Linux? If no, what is the difference between them?
- Can we set the session connection and reconnection time out period using the APIs?
- Is it possible to get the notification using APIs whenever the user gets disconnected from the session?
- What is tenant ID?
Can someone explain me what is tenant_id and tenant_nonce in the following post ?
https://community.teamviewer.com/t5/Knowledge-Base/Remote-Access-API-Integration-Guide/ta-p/32318
Also clarify if there is any API for unattended remote control.
