How to retrieve API token after a custom host is created
I created a custom host and allowed account assigment via the Assignment tool. This shows the API token once. I was wondering if there's a way to show the API token once you've enabled it?
Thanks!
christian-j Posts: 54
open https://login.teamviewer.com/nav/deploy in the browser.
Open one custom module by double click.Remark:
Only the creator of the custom module can see the API token.Team Lead Product Development (Enterprise)
Did my reply answer your question? To help others, please accept it as solution. Thanks!6
Hi Michaelvds,
on the device itself it's not possibility to see / get the API token, which was used for the installation / assignment.
Within the Management Console you could get it, if the custom module still exists.
Your remark was the key, thanks a lot!
