Is there a plan to update the TV in Synology devices to version 14? Seems I have upr-graded all of my computrs and can't connect to the DS218j. Should the Synology package (beta) work, or should I manually install the TV package?
The darn password, when entered into the "Assign to account" box, is declared wrong, hence no assignment possible, hence no connection possible.
I'm just fed up with how bad this is developed. Calling it beta, not issuing any update on weeks or even months and simply letting users on their own.
Oh and those g-o-d-d-a-m-n captchas, always requiring about 5 or more rounds - as if 2FA wouldn't be enough to secure - and proof! - that I'm a) a human and b) valid user.
At the moment I don't have any clue why password is not showing up. I don't see any reason in which this would happen. The only thing I could ask you to check from your side, at the moment, is that in your settings "protection against cross-site" is activated which you could find in "Control Panel"->Security ->"Improve protection against cross-site request forgery attacks" .
I would be needing more time for this. Meanwhile, you could directly take the serial number of your synology device("control Panel" -> "info center") for the password and assign the device to your account.
Could you please send me the logfile. To download the logfile, click on the "Download Support Information". Also, are you using the actual Synology device or the virtual DSM? If it is virtual DSM, then it is not supported by us.
Please download the logfiles twice, one before the making the assignment and one after the error happens due to the assignment failure.
@arpitjindal > If it is virtual DSM, then it is not supported by us.
I guess that makes downloading log files unnecessary. While it's technically nearly equal, you opted for not supporting Virtual DSM. Great, really.. not! May I at least ask what's the ETA for such support?
Are you facing this problem always? So, not even once you are able to connect to your device? If that is the case, then please download the logfiles by clicking "Download Support Information" and directly send it to me.
Yes, it's a virtual DSM, hence any logfile is probably obsolete.
Nonetheless, that VM, together with a couple more VMs, runs on a 716+II DSM to comply with SOC (separation of concerns, i. e. 1 VM per concern, e. g. DBs, website files, webserver, etc.) which helps minimize both, security vulnerabilities and admin tasks like updates.
I therefore request immediate support for virtual DSM as it's almost identical to any "real" DSM.
Is Health Monitoring supported on Synology devices? If so, how does one go about activating Operating System Health Monitoring on a Synology DS1812+ for example?
FYI, we are running version 2.3.7 of TeamViewer on the NAS.
Hi@Aktarus
Are you still facing this problem?
@mickwish
It should work with the current package. What is the error you are getting?
YES, it's still the same this morning ..
I got only the ID .. no password .. and If i try to connect tho this ID from another computer, I got an error ...
@mickwish
Could you post the screenshot?
And also, have you assigned the device to your account? For more information about the assignment process, read the first page of this forum
I second that issue - [email protected] is simply unable to accept the password provided by [email protected], see:
@_Andreas_/ @arpitjindal please, once and for all, fix this mess!
I didnt properly understandyour probem
Hi @Aktarus
Hi @mickwish
If you are still facing the problem then could you please post the screenshot of the error?
Hi @ThreadRipper86
Hello All TeamViewer Users,
Final TeamViewer package has been released for Synology, available directly from Synology package center. This package includes:
Please download/update your Synology's TeamViewer package.
Enjoy
Thank you! Now TV works as expected with my DS218j.
Mickwish
@arpitjindal
Hi@ThreadRipper86
At the moment, We don't plan to support virtual DSM.
Is the Synology 1512+ supported? Which version i have to download it?
Hi @Sniper8952
The new version is now being added in Synology package center. You could directly install it from there.
Hi arpitjindal
If i install it, i can't connect with my PC Teamviewer to the Synology Teamviewer Server. My Computer can't find the Server.
Hi @Sniper8952
Could you tell me what error are you getting? And also how are you connecting to it? Did you assign the device to your account first?
A connection could not be established
Eine Verbindung konnte nicht hergestellt werden.
I connect in the same network.
Hi @Sniper8952
Same problem, no ID and no password on 1019+.
Restart, reinstall app, same problem
same here
@arpitjindal,
couldn't reply sooner, sorry about that.
Is there a verssion that supports Synology NAS DS413 (Freescale chipset)?
Thanks in advance,
~Andrew~
I asked 1 year ago by when will come support for macOS and Android. I has been said it is on the roadmap.
Any news on that ?
Hi @ThreadRipper86
Thanks for the use case. We will look into it and try to find the solution as-soon-as-possible.
Hi @kc6108
Operating System Health Monitoring is not supported on Synology Device.
