Are you working with Insider Builds❓
Participate in our survey and get to know the new UI 👉 here 👈.
Can not create session
I create session but i'm get error "Failed to parse input"
i use postman and sent method POST from link:
https://webapi.teamviewer.com/api/v1/sessions?groupid=g75436837
my error:
"error": "invalid_request",
"error_description": "Failed to parse input.",
"error_code": 1
 I try use api get full list session and it run success, but i create session same above i get error. Please help me, thanks.
  • Hello,
    you need to put the parameters (e.g. groupid) in JSON format into the request body.
    Please check the example in our API documentation on page 32.
    Team Lead Product Development (Enterprise)
    Did my reply answer your question? To help others, please accept it as solution. Thanks!
