Are you working with Insider Builds❓
Participate in our survey and get to know the new UI 👉 here 👈.
COM API
Enny
Enny Posts: 3 ✭✭
In
https://community.teamviewer.com/t5/Knowledge-Base/Command-line-parameters/ta-p/34447
there is an COM API mentioned. I can instance an com Objet, and i figured out som methodnames, but unfortunatelly I can't  find any documentation.
Is there an documentation for COM API and is it still in active development....
  • mLipok
    mLipok Posts: 777 ⭐Star⭐
  • Enny
    Enny Posts: 3 ✭✭
    I could get the Interfaces and Methods, but I think you need a Token (aScript Token does not work):
    // Generated .IDL file (by the OLE/COM Object Viewer)
    // typelib filename: TeamViewer.exe
    uuid(D5883D5C-5456-4BF9-844A-3F8C5E61AF9F),
    version(1.2),
    custom(DE77BA64-517C-11D1-A2DA-0000F8773CE9, **Please do not post TeamViewer IDs**),
    custom(DE77BA63-517C-11D1-A2DA-0000F8773CE9, **Please do not post TeamViewer IDs**),
    custom(DE77BA65-517C-11D1-A2DA-0000F8773CE9, "Created by MIDL version 8.01.0622 at Tue Jan 19 04:14:07 2038
    library TeamViewer
    // TLib : OLE Automation : {00020430-0000-0000-C000-**Please do not post TeamViewer IDs**46}
    importlib("stdole2.tlb");
    // Forward declare all types defined in this typelib
    interface ITvMachineSettings;
    interface ITvUserSettings;
    interface ITvAddress;
    interface ITvVersion;
    interface ITvSession;
    interface ITvMeetingSession;
    interface ITvSessionList;
    interface ITvConverter;
    interface ITvConverter2;
    interface ITvScheduledMeeting;
    interface ITvScheduledMeeting2;
    interface ITvScheduledMeetingList;
    interface ITvAccount;
    interface ITvApplication;
    interface ITvApplication2;
    interface ITvService;
    typedef enum {
    TvApplicationTypeUnknown = 0,
    TvApplicationTypeStandard = 1,
    TvApplicationTypeQuickSupport = 2,
    TvApplicationTypeQuickJoin = 3,
    TvApplicationTypePortable = 4,
    TvApplicationTypeHost = 5
    } TvApplicationType;
    typedef enum {
    TvSessionTypeUnknown = 0,
    TvSessionTypeRemoteControl = 1,
    TvSessionTypeMeeting = 2,
    TvSessionTypeFileTransfer = 3,
    TvSessionTypeVpn = 4
    } TvSessionType;
    typedef enum {
    TvAddressTypeUnknown = 0,
    TvAddressTypeUnspecified = 1,
    TvAddressTypeLocalNetwork = 2,
    TvAddressTypeTeamViewerId = 3,
    TvAddressTypeMeetingId = 4
    } TvAddressType;
    typedef enum {
    TvSessionFlagsNone = 0,
    TvSessionFlagUnknown = 1,
    TvSessionFlagServer = 2,
    TvSessionFlagClient = 4
    } TvSessionFlags;
    typedef enum {
    TvTextResourceIDUnknown = 0,
    TvTextResourceIDMeetingDefaultInvitation = 1,
    TvTextResourceIDMeetingDefaultLocation = 2,
    TvTextResourceIDMeetingDefaultSubject = 3,
    TvTextResourceIDMeetingURLPrefix = 4,
    TvTextResourceIDMeetingCustomInvitation = 5,
    TvTextResourceIDMeetingCustomSubject = 6
    } TvTextResourceID;
    odl,
    uuid(A20E949F-5456-4A49-BE51-88077E13F793),
    dual,
    oleautomation
    interface ITvMachineSettings : IDispatch {
    [id(0x60020000), propget]
    HRESULT IsPasswordRequired([out, retval] VARIANT_BOOL* pbResult);
    [id(0x60020001)]
    HRESULT UnlockWithPassword(
    [in] BSTR sPassword,
    [id(0x60020002)]
    HRESULT UnlockWithHash(
    [in] BSTR sSaltedPasswordHash,
    [in] BSTR sPasswordSalt,
    [id(0x60020003)]
    HRESULT SetPermanentPassword([in] BSTR sPassword);
    [id(0x60020004), propget]
    HRESULT HasPermanentPassword([out, retval] VARIANT_BOOL* pResult);
    [id(0x60020005)]
    HRESULT AddAdditionalPermanentPasswordWithKey(
    [in] BSTR sKey,
    [out, retval] VARIANT_BOOL* pbWasAdded);
    [id(0x60020006)]
    HRESULT DeleteAdditionalPermanentPasswordWithKey(
    [in] BSTR sKey,
    [out, retval] VARIANT_BOOL* pbWasDeleted);
    [id(0x60020007)]
    HRESULT HasAdditionalPermanentPasswordWithKey(
    [in] BSTR sKey,
    odl,
    uuid(DB86189D-5456-4B7B-B5AB-419653E156DD),
    dual,
    oleautomation
    interface ITvUserSettings : IDispatch {
    [id(0x60020001)]
    [id(0x60020002)]
    [id(0x60020003), propget]
    HRESULT DisplayName([out, retval] BSTR* psName);
    [id(0x60020003), propput]
    HRESULT DisplayName([in] BSTR psName);
    [id(0x60020005), propget]
    HRESULT MeetingName([out, retval] BSTR* psName);
    [id(0x60020005), propput]
    HRESULT MeetingName([in] BSTR psName);
    odl,
    uuid(D399478A-5456-4112-B963-38E6C8AA1217),
    dual,
    oleautomation
    interface ITvAddress : IDispatch {
    HRESULT AddressType([out, retval] TvAddressType* pType);
    [id(0x60020001), propget]
    HRESULT Value([out, retval] BSTR* psValue);
    odl,
    uuid(BF93CDAB-5456-4611-AE2C-6F50A41564C1),
    dual,
    oleautomation
    interface ITvVersion : IDispatch {
    HRESULT Major([out, retval] int* piMajor);
    HRESULT Minor([out, retval] int* piMinor);
    [id(0x60020002), propget]
    HRESULT Build([out, retval] int* piBuild);
    HRESULT Extra([out, retval] BSTR* psExtra);
    [id(0x60020004)]
    HRESULT ToString([out, retval] BSTR* psStr);
    odl,
    uuid(F274CC23-5456-42B2-AC7A-5C5EA0D6EFBC),
    dual,
    oleautomation
    interface ITvSession : IDispatch {
    HRESULT SessionType([out, retval] TvSessionType* pType);
    HRESULT SessionFlags([out, retval] TvSessionFlags* pFlags);
    HRESULT RemoteAddress([out, retval] ITvAddress** ppAddress);
    odl,
    uuid(6EB079FD-5456-432D-BDAB-9B38DF8DD0EE),
    dual,
    oleautomation
    interface ITvMeetingSession : ITvSession {
    [id(0x60030000), propget]
    HRESULT Password([out, retval] BSTR* psPassword);
    odl,
    uuid(457E4C9C-5456-471C-8A3C-F3BFC8DF242C),
    dual,
    oleautomation
    interface ITvSessionList : IDispatch {
    HRESULT Count([out, retval] long* piCount);
    [id(0xfffffffc), propget, restricted]
    HRESULT _NewEnum([out, retval] IUnknown** ppEnum);
    [id(00000000), propget]
    HRESULT Item(
    [in] long iIndex,
    [out, retval] ITvSession** ppSession);
    [id(0x60020003)]
    HRESULT UpdateLocalCopy();
    odl,
    uuid(95C0F21E-5456-4891-B9F6-014E98858D0B),
    dual,
    oleautomation
    interface ITvConverter : IDispatch {
    [id(0x60020000)]
    HRESULT ApplicationTypeToString(
    [in] TvApplicationType type,
    [id(0x60020001)]
    HRESULT SessionTypeToString(
    [in] TvSessionType type,
    [id(0x60020002)]
    HRESULT AddressTypeToString(
    [in] TvAddressType type,
    [id(0x60020003)]
    HRESULT SessionFlagsToString(
    [in] TvSessionFlags flags,
    [id(0x60020004)]
    HRESULT StringToApplicationType(
    [in] BSTR sStr,
    [out, retval] TvApplicationType* pType);
    [id(0x60020005)]
    HRESULT StringToSessionType(
    [in] BSTR sStr,
    [id(0x60020006)]
    HRESULT StringToAddressType(
    [in] BSTR sStr,
    [id(0x60020007)]
    HRESULT StringToSessionFlags(
    [in] BSTR sStr,
    odl,
    uuid(14B59F6C-4FF8-4AD9-BA71-D65FDF7AEC3B),
    dual,
    oleautomation
    interface ITvConverter2 : ITvConverter {
    [id(0x60030000)]
    HRESULT TextResourceIDToString(
    [in] TvTextResourceID trID,
    [id(0x60030001)]
    HRESULT StringToTextResourceID(
    [in] BSTR sStr,
    [out, retval] TvTextResourceID* pTrID);
    odl,
    uuid(550C2D70-5456-4990-A6B2-20E1EF1C8EBC),
    dual,
    oleautomation
    interface ITvScheduledMeeting : IDispatch {
    HRESULT IsAttached([out, retval] VARIANT_BOOL* pbIsAttached);
    HRESULT StartTimeUtc([out, retval] DATE* pStartTime);
    [id(0x60020001), propput]
    HRESULT StartTimeUtc([in] DATE pStartTime);
    HRESULT EndTimeUtc([out, retval] DATE* pEndTime);
    HRESULT EndTimeUtc([in] DATE pEndTime);
    HRESULT Address([out, retval] ITvAddress** ppAddress);
    [id(0x60020006), propget]
    HRESULT Subject([out, retval] BSTR* psSubject);
    [id(0x60020006), propput]
    HRESULT Subject([in] BSTR psSubject);
    [id(0x60020008), propget]
    HRESULT SaveForReUse([out, retval] VARIANT_BOOL* pbSaveForReUse);
    [id(0x60020008), propput]
    HRESULT SaveForReUse([in] VARIANT_BOOL pbSaveForReUse);
    [id(0x6002000a), propget]
    HRESULT CustomIdentifier([out, retval] BSTR* psCustomID);
    [id(0x6002000a), propput]
    HRESULT CustomIdentifier([in] BSTR psCustomID);
    [id(0x6002000c), propget]
    HRESULT CustomConferenceData([out, retval] BSTR* psConferenceData);
    [id(0x6002000c), propput]
    HRESULT CustomConferenceData([in] BSTR psConferenceData);
    [id(0x6002000e)]
    HRESULT Commit();
    [id(0x6002000f)]
    HRESULT Delete();
    [id(0x60020010)]
    HRESULT StartMeeting();
    odl,
    uuid(AD9D431B-3B37-4F4A-B676-D43D8AEAD6E2),
    dual,
    oleautomation
    interface ITvScheduledMeeting2 : ITvScheduledMeeting {
    HRESULT ConferenceData([out, retval] BSTR* psConferenceData);
    odl,
    uuid(1B1BD342-5456-4F9F-A027-1BA0254C8C0A),
    dual,
    oleautomation
    interface ITvScheduledMeetingList : IDispatch {
    HRESULT Item(
    [in] long iIndex,
    [out, retval] ITvScheduledMeeting2** ppMeeting);
    [id(0x60020003)]
    odl,
    uuid(BDBA72AF-5456-49B0-875B-F9122A78D9FB),
    dual,
    oleautomation
    interface ITvAccount : IDispatch {
    HRESULT AccountName([out, retval] BSTR* psAccountName);
    [id(0x60020001)]
    HRESULT CreateScheduledMeetingList([out, retval] ITvScheduledMeetingList** ppList);
    [id(0x60020002)]
    HRESULT CreateScheduledMeeting([out, retval] ITvScheduledMeeting2** ppMeeting);
    odl,
    uuid(09183D47-5456-4B6E-BA7E-F170D9F4ABEE),
    dual,
    oleautomation
    interface ITvApplication : IDispatch {
    [id(0x60020000)]
    HRESULT UnlockToken([in] BSTR sGuid);
    [id(0x60020001)]
    HRESULT LockToken([in] BSTR sGuid);
    [id(0x60020002)]
    HRESULT CreateConverter([out, retval] ITvConverter** ppConverter);
    [id(0x60020003)]
    HRESULT CreateAddress(
    [in] BSTR sValue,
    HRESULT ApiVersion([out, retval] ITvVersion** ppVersion);
    HRESULT ApplicationVersion([out, retval] ITvVersion** ppVersion);
    HRESULT MachineSettings([out, retval] ITvMachineSettings** ppMachineSettings);
    [id(0x60020007), propget]
    HRESULT UserSettings([out, retval] ITvUserSettings** ppUserSettings);
    HRESULT ApplicationType([out, retval] TvApplicationType* pType);
    [id(0x60020009), propget]
    HRESULT TeamViewerId([out, retval] int* pId);
    HRESULT HasActiveSession([out, retval] VARIANT_BOOL* pbResult);
    [id(0x6002000b)]
    HRESULT CreateSessionList([out, retval] ITvSessionList** ppList);
    [id(0x6002000c)]
    HRESULT RequestHostMeeting([in] BSTR sPassword);
    [id(0x6002000d)]
    HRESULT RequestConnectTo(
    [in] ITvAddress* pAddress,
    odl,
    uuid(2F5E4D7D-7181-44DC-8407-CAF525D85345),
    dual,
    oleautomation
    interface ITvApplication2 : ITvApplication {
    [id(0x60030000)]
    HRESULT CreateConverter2([out, retval] ITvConverter2** ppConverter);
    [id(0x60030001)]
    HRESULT GetAccount(
    [in, optional, defaultvalue(0)] VARIANT_BOOL bAllowInteractiveLogin,
    [in, optional, defaultvalue(0)] long hwndParent,
    [out, retval] ITvAccount** ppAccount);
    [id(0x60030002)]
    HRESULT GetTextResource(
    [in] TvTextResourceID textID,
    [out, retval] BSTR* pTextRes);
    odl,
    uuid(FC73DAE1-5456-440C-B6EE-0D4A235B71B5),
    dual,
    oleautomation
    interface ITvService : IDispatch {
    [id(0x60020000)]
    [id(0x60020001)]
    HRESULT ServiceVersion([out, retval] ITvVersion** ppVersion);
    uuid(877D726A-5456-4171-9CDB-0DAB3AFFE07F)
    coclass TvApplication {
    [default] interface ITvApplication2;
    uuid(CFDFB010-5456-4D0B-8A07-B55C0B963627)
    coclass TvService {
    [default] interface ITvService;
