Today update for Synology v2.8.17 is not working
gatoseco
gatoseco Posts: 1
Today update for Synology v2.8.17 is not working.
I have a DS918+ it was working fine with previous versions, but with this update, it shows the TV screen in blank.
  • _Andreas_
    _Andreas_ Posts: 19 Staff member 🤠
    Hi @gatoseco!
    Thank you for reporting this problem. Would it be possible to forward the logfiles from both sides (Windows and Synology) to support?
    You can send a message directly to iot-support@teamviewer-iot.com
    Sorry for the inconveniences,
      Andreas
