Hello, I have been able to deploy teamviewer into windows computers but in our school we count with many Mac and Chrome OS devices. I wanted to know how to install it keeping the settings and assigment that we use for Windows.
if you want to rollout TeamViewer on macOS, this article will help you: Mass deployment on macOS. Assignment will also work, but importing settings isn't supported on macOS yet.
For Chrome OS, there is currently no mass deployment possibility.
Hi Sven_F, There is no need to deploy it massively. I just want to know how to install it in Mac and Chrome OS, which installer I have to use and if I have to set them all up, by one one.
Ok, great, I could try Chrome OS extension, but it seems to be user based, so each user has to install it. Regarding Mac, I could install it and set it up, but it is telling me that the client has a newer version and I have Teamviewer 13 license. Do you know where can I get Teamviewer 13 download for mac?
I am not sure if I am on the right place or not. My computer was broken into and I am not trying to make sure that both my and my 96 year old mother's computer are 1. protected on Teamviewer and 2. That her computer is set so that I can get into her computer when it is asleep. Someone at Teamviewer kindly helped with this process but I must have misunderstood something.
1. I now understand that the password changes each time so theoretically no one can get into her computer without knowing the password. However, I keep getting messages on my computer that say:
"DorothyaltmansiMac.attlocal.net has signed in" when there is definitely no one on the her computer. I, on the other hand, am no longer able to connect with her computer.
I think that I may have gotten some of the instructions wrong. My notes say:
1. Change Mom's pw's under security for unattended access on both computers-mine in Boston and hers in FL.
Something about: preferences, security, preferences easy access, preferences-general-but I don't any longer understand what that means and when we tried couldn't find everything. Would really appreciate help.
@Vatsilidis I would like to have teamviewer host run on my Mom's Chromebook so when she needs help, I can remotely connect to her chromebook from my pc.
We are happy to announce that you can now share the screen of your devices running ChromeOS. ?
If you want to connect via unattended access, please use the TeamViewer Host. If you want to connect spontaneously, please use the TeamViewer QuickSupport.
Hi @LincolnAEL,
Sven
Thanks,
Hi @LincolnAEL,
you can just download the according packges for each OS:
Afterwards install them on every computer (one by one) by double-clicking on the package and follow the instructions.
Sven
Thanks,
Hi @LincolnAEL
you can find older versions of TeamViewer here: https://www.teamviewer.com/en/download/previous-versions/
Sven
Thank you.
Wendy A.
The installer for chrome ops IS NOT a host installer.
Hi @hogriderj
What do you want to do that this app doesn't provide it?
Best regards
Have you tried to set up the unattended access to the remote pc?
You can see the How to Setup Unattended Access.
I hope this will solve it for you.
Best regards
Hello @hogriderj,
You will find the download links here:
Alternatively, you can also download these versions directly on our website here: TeamViewer for Chrome OS
Please also find additional information here: Supported platforms - Chrome OS
