Multible Accs signed in at a time & joining Confernce Calls easier from mobile
Hello all,
today we had a conference call in which we needed a person to be present who was in his car and didn't have the Blizz app installed, so he tried to join by dialing in the number, but because of all the steps had would have to go through with pressing the number for the language or putting in the code he wasn't able to join since he had to drive his car, so in the group the question occurred if you could just join by putting in the number and the code behind it with a comma inbetween, like skype does it. Another question the came up in the same call was if you are able to be logged into multible accounts at the same time so then if you need to join a call on the other account you can just hop into it instead of logging out with one account and then logging in with the other.
Thanks for any replys in advance.
Bennn
Best Answers
Multiple accounts:
You can not be logged into multiple accounts on one device at the same time. Nevertheless, you can join mulitple meetings at the same time using the same account with the same client.
Easy dial-in:
You can dial into in a known meeting with one click by putting the parameters (phone number, language selection, meeting id) attached to the number and seperated with a ",", e.g. +4971613569600,1,12345678. So for regluar meetings you would just save this number as a contact.
If you have the app installed on iOS you can also use the Blizz Widget to easily see and join/start your next meeting.
5 -
No, that's not possible.
You can only have one client running with one account logged in, but join multiple meetings. Usually you would join all meetings with one account identifying yourself.
5
First of all I wanna thank you for your response, but I have another question. Could you be able to register two accounts like in two different tabs/batches so that it's easier for one to switch faster from one account into the other? From the convenient perspective it would make it easier if you have two different Blizz Icons on your desktop so you are able to log into your accounts faster and you could also switch faster between your accounts to join different calls or conversations.
Thank you for your replys in advance.Bennn
