android 4.4.2 remote control
Hello!!
I have a problem.
I have a samsung C115 K zoom, witch i still use as a cammera for his quality images.
with android 4.4.2 on it.
I could access it remotely until teamviewer returned a message that I needed to update to a newer version.
I updated the host on the Samsung C115. it lets me enter and access it but the remote access part is disabled.
I also tried other models of samsung C115 K zomm. same problem.
if I don't update, it won't let me access it. if I update I no longer have the remote option.
but otherwise all the options work.
Please help me, if possible.
Thank you!!!
Hello @bosbto,
To use the TeamViewer apps, the latest version of Android 4.4 is required, which means Android 4.4.4. Please see our article: Compatibility - Android
You might need to update your Android OS to the 4.4.4 version to be able to use our apps.
Best regards
