my Wake on LAN - public ip - does not work
marcoTV
marcoTV Posts: 3 ✭✭
I am configuring some remote PCs.
I should be able to wake up them in case they are down (the offices can be empty...).
I have configured, for the time being, a single PC and I am able to wake up it via LAN (I access remotely to another PC and via this PC I can wake up my target, using a wol.exe application).
The next step is to wake up this PC via internet (if all the PCs f the LAN are down...), and I have enabled "Wake on LAN" on teamviewer:
1. the PC is assigned to my account (I manage it via the Teamviewer console https://login.teamviewer.com/)
2. the router has a dynamic public address
3. I enabled port forwarding for UDP 9 to broadcast (192.168.1.255)
4. I set the dyn ip address on the Wake on LAN configuration on teamviewer
when the PC goes down i see the "Restart" option on teamviewer console, so I guess that my console recognize that the PC is down
but when I click "Restart" nothing happens...where is my mistake? what is missing?
thank you very much for your support!
marco
Howdy, Stranger!
