We are using 15.11.6 and the setting of the metting settings will no be saved or are resetted after PC reboot with a normal Domain-User. I guess its a software-quality issue. Will there be an update?
Hello Jean,
its the setting:
Erweiterte Einstellungen für Meeting -> Zugriffskontrolle:
In that dropdown-box we select Vollzugriff. Now we get in a meeting-invitation from an other company. At that point we cant make the other-meeting operator allow to controll our machine. Then I look in the settings and now the meeting-settings is not at Vollzugriff, but to Eigene Einstellungen with not allow to control the machine remote. I kill teamviewer.exe Start Teamviewer new, make the meeting-settings to Vollzugriff and after some of this Procedure I can allow the meeting-starter to controll the PC. We both have the above named Version.
best regards
michael
Hello @hans-wurst,
Thank you for your message. ?
Which of the meeting settings are you referring to? Could you please a little more precise?
Best regards
