My Remote Desktop screen is very small and I can’t adjust it.
Thanks again for your help. I had a full screen a couple days ago when this condition just started happening. Ii just got a new computer with new monitors in December of 2020. I can't say anything about a bug.
MV
@Michael_Ves This means that TeamViewer can only capture one resolution on your remote screen.
This might be the case if:
Thanks for responding JeanK . When I try to access the other resolutions from the pull down menu, there is no pull down.
Hello @Michael_Ves,
You can change the resolution of the partner's screen within the TeamViewer toolbar:
See what's new at TeamViewer
