after connection to remote,
remote computer sounds are normal at remote,
however as soon as remote unmutes their microphone
all sound is lost,
my mic still works and can be heard by them,
but all sound from from remote pc is lost.
Do you know how to stop the manipulation of the soundcard while being connected from my computer to others ? This is annoying and started after latest update of the Teamviewer App.
It's the same for me and I HATE it and want to disable that feature.
Is there a way to stop Teamviewer Remote from adjusting the soundcard ?
This started when I recieved the latest updated version of the app.
I want to disable that feature as I annoys me when listening to music while giving remote support to friends and family. It should NOT affect the soundcard connecting to a remote computer from mine.
When I connect it to a computer, my computer sound goes down
Hello @marks199,
If you are using a third-party product for your audio calls, then it is expected behaviour.
TeamViewer lowers the audio output of other participants to prioritize the TeamViewer audio feature.
I recommend you to use the in-session VoIP feature. With the feature, you will be able to communicate with your remote users via audio without any issue.
