Is there a Teamviewer program that allows remote connection only but not the remote control?
Hello @Timez,
Yes, this is possible.
People who are sensitive to remote control can set up their TeamViewer so per default, all incoming connections are only allowed to view their screen (and use the blue cursor). The remote control is here disabled.
They need to:
You can also follow this animation I made for you:
See what's new at TeamViewer
