I am trying to get TeamViewer to run on a Fedora 32 instance after a reboot and without having to login to a user first. I am attempting to connect to it from a Windows 10 laptop, but I am receiving the "No Connection to partner! Partner did not connect to router. Error Code: WaitforConnectFailed" error. If I am logged into the user on the Fedora box, I can connect without a problem. If I log out of the user on Fedora, I can see it is available when looking at online machines in my Windows 10 machine, but cannot connect.
So far I have ensured all advanced settings are correct with allowing full access. I have validated that the TeamViewer service is running on Fedora. I have also disabled IPv6 protocols on both machines. Multiple reboots as well.
Anyone have any guidance on next troubleshooting steps or solutions? I appreciate your help.
Thanks!
