How to monitor apps running on Windows 10 worstation with TeamViewer?
I'm trying to either set an alarm or find a place that indicates when a windows program is running. In windows 10 task manager it shows up under "apps". I have a program that after it is closed, there is a "process" that sometimes doesn't close. This causes issues with other network users trying to use the program or app. I have set an alarm in teamviewer to alert me when the "process" is running, however I don't want to know if it's running when the program is open, only when the program is closed and the process hans't ended.
HI @CCI_Gary,
Thank you for contacting TeamViewer Community.
Unfortunately, we cannot fully understand your inquiry.
Can you provide more information in details about your question please?
Thank you for your understanding.
Best Regards,
Akiho
