Hi
Since last weeks, I see in the registry TeamViewer is not installed in
HKEY_LOCAL_MACHINE\Software\Wow6432Node\TeamViewer\
but in
HKEY_LOCAL_MACHINE\Software\TeamViewer\
I use a vbs script with ocsinventory, I changed the path in the vbs but it's not working anymore
Why TeamViewer is not installed in Wow6432Node ?
I have donwloaded the last version, change nothing
Is it a problem of lastest version of TeamViewer or Windows ?
Below the vbs script wortking well with computers before this summer
Set WshShell = CreateObject("Wscript.Shell")
Dim RegTVClientID,RegTVVersion
Dim arrSubKeys(3,2)
arrSubKeys(0,0) = "TeamViewer"
arrSubKeys(0,1) = "HKEY_LOCAL_MACHINE\Software\Wow6432Node\TeamViewer\ClientID"
arrSubKeys(0,2) = "HKEY_LOCAL_MACHINE\Software\Wow6432Node\TeamViewer\Version"
For x = LBound(arrSubKeys, 1) To UBound(arrSubKeys, 1)
RegTVClientID = WshShell.RegRead( arrSubKeys(x,1) )
RegTVVersion = WshShell.RegRead( arrSubKeys(x,2) )
If Not IsNull(RegTVClientID) AND RegTVClientID <> "" Then
'MsgBox RegTVClientID, vbInformation
'MsgBox RegTVVersion, vbInformation
Wscript.Echo "<TEAMVIEWER>"
Wscript.Echo "<TVCLIENTID>" & RegTVClientID & "</TVCLIENTID>"
Wscript.Echo "<TVVERSION>" & RegTVVersion & "</TVVERSION>"
Wscript.Echo "</TEAMVIEWER>"
Exit For
End If
Next
Thanks for your help
