I have to set up a lot of Android devices with TeamViewer Host. (They are custom built devices that run on Android 7.1.2). Is there a setting I can change so the Eco-Mode is disabled by default?
Thanks in advance :)
So from our perspective, TeamViewer uses the eco-mode by default once the app is installed.
If there is a way to disable it via ADB, maybe you could ask on a forum that is specialized in ADB.
/JeanK
Hi @JeanK ,
I want to disable it, because it is unnecessary. The devices I have are not battery powered, so Eco-Mode doesn't do anything. I am using ADB to install TeamViewer. Is there maybe a way I can use ADB to disable eco mode as well, it is set in some settings file that is stored locally?
Hello @MariusS,
After talking to an engineer, I can confirm that it is not possible to disable the Eco-mode by default.
Once the application is installed, it is turned on automatically as default.
Can you share a little more information about why you want to disable it? Maybe we can help you further.
Would like to be able to disable Eco mode on the Android Host either by adb or through something in the Management Console, and preferably loads at a time. Any chance of this being possible?
