Hi.
I have 3 Linux servers at home, all installed with Ubuntu 18.04. When working outside of the home, I sometimes need to access one of those machines.
Yesterday, out of the blue, one server started to act weird. When I try to connect with it from my Mac, it displays the screen of initiating a connection and is stuck there. On the server, it looks like I am logged in and it shows this small window that shows that there is an active connection. After several seconds, it disconnects, and I cannot try to reconnect at all, I have to restart the server.
The 2 other servers are working great.
I uninstalled and reinstalled teamviewer from that server 5 times but nothing worked. I cleared all the cache files in ~/.config, ~/.local/share and ~/.cache. Still, nothing. Don't understand what is the difference between this machine and the two others, and it started without no modifications to the server.
I removed the checkbox from "using udp" from both server and client as it was suggested in a forum, but it didn't help.
Thanks,
Ofer
