Hi, i normally use teamviewer to connect to android devices via quick support for tech support...
Since a few weeks we expierence problems with new android devices:
I can connect normally and i see the homescreen, but as soon as i open any app the screen goes black (on my pc, on the device you see all normal). And so i cant do anything except opening apps.
I have not figured out how to solve this and i cant find similar entrys on google.
I am also not sure if this is "repairable" by teamviewer or if its a problem with new security options for android.
Any suggestions? Do you have similar experiences?
The version i testet last was a Samsung SM-A326B running android 12.
