Hi All,
I have several Android Units running my Custom Host APK for unattended remote access, which i have installed manually and assgned manually. The android systems are rebooted daily and all seems to work fine most of time. I can connect to majority of the android devices via the Teamviewer Computers & Contacts tab. However on some occasions, devices are shown online via Teamviewer Computers & Contacts, but connections are refused stating incorrect authenitication. I have done some research on this and have found that during the power down of the unit, sometimes teamviewer gets corrupted and then removes the assignment hence no connection is ever possible. Host app is running fine, it simply removes the assignment???
This is a big problem as i cannot go to all devices and reassign them manually.
Is there any way that I can re-install using the URL "https://get.teamviewer.com/xxx" without having to click on the Assign Pop-Up?
Ideally i would like to run the URL and it installs and assigns itself.
Rakesh
