Hello, just wondering if anyone else is unable to hear sound from the host machine using the web client with the remote access license. If so, have you found a solution? Thanks in advance for any responses.
Same here. I can't believe there have only been two posts on this topic.
Hi. Same for me. I assume you are also using the free license. Based on searching around in forums, I suspect that they intentionally omit the feature, to motivate folks to buy paid license.
