Dear all,
I need to use phone nr 1 (android) to control remotely phone nr 2 (android). I installed Teamviewer app on phone 1, and teamviewer Host on phone nr 2. I have adjusted the settings, so I can start controlling phone 2, without the request of authentication or acceptance. From the app in phone 1 in my hands I select phone 2, and I can immediately control it remotely. So it works fine. The problem is it works only once... When I close the teamviewer session from phone nr 1, then if I want to connect a second time, it does not work anymore.... I need to close and re-open Host in the phone nr 2, which of course is not possible since I have in my hands only phone nr 1.... Can you have an explanation on why it works only one time, and not the second time ? Are there some settings I can change, to solve this problem ?
Thanks a lot in advance for support !
