Checkbox may have been checked and we use host only Teamviwer. It says you can clear the checkbox in profile setting but could not find it.
Yes, that was successful for me. There was no entry under the browser option because I did not have the don't ask checkbox selected.
Yes, that did work for me. I did not have the don't ask checked so there was no entry under the browser option.
Hi @Ed_D,
Welcome to the TeamViewer Community! 🚀
You can edit this choice by following these instructions:
You will find here the settings you have configured. You can reset the settings by deleting the entry.
/JeanK
Cannot find where in the profile settings to reset the choice
