Recent Connections List - Column Widths Problem
randy1616randy
Posts: 7 ✭✭
In the NEW interface, the Recent Connections list has a very narrow column width for the Name so that I cannot see the full text. If I make it wider, the button on the right side for Connect may not be visible as it disappears off the side of the window.
There is a lot of whitespace to the right of the Recent Connection column so no reason for this. It does not work this way on the other lists (All Devices or selected Group). On those lists if you adjust a column width, to be too wide, it automatically makes another column narrower so the Connect link is not lost.
It should also remember your column width and Window size choices.
