I login to my client
And I change default resolution to 1280x1024, then I was doing something....
And I switch to second remote Monitor, now I see the second client monitor and I also witch to 1280x1024, and of course I was doing something....
After this I had something to do on first Monitor so I switched to them.
What I notice is that TeamViewer do not remeber the fact that I was set up resolution to 1280x1024, and the same when I switch back to Second Monitor.
Each time I switch between remote monitors the resolution is going to be changed.
Could any body confirm the same problem ?
Whether any body have any solution to this problem ?
mLipok
