Since using the new UI, I have noted that when I click the Ctrl+Alt+Del on the Remote session toolbar, the login screen appears for the remote machine, but the text editor to enter the password is not selected. You have to click the field to focus it before you can type the remote password.
This is very annoying as, on many occasions I start typing and nothing happens. Especially with the previous version, this did not happen.
I this a bug or a 'feature'?
Thanks, Martin.
