I am trying to have almost the same as the classic view...
As stated on another post I always install Teamviewer on all customer computers.....I try to make things as easy as possible for them...
I have been looking at the unattended connection... which seems promising....
I have set this up on a "test computer" and then in advanced settings added the password I want to use....from my host computer
When I connect to the "test computer" I add the password I have created on test computer and the connection works as it should....BUT the password is supposed to be saved on my host computer , so that I don't have to add it every time...but that is not working...
What is the solution?
P.S. The downfall to this is if they are online at any time I can connect to that computer without their consent and that sort of defeats the object....What is going on? The old classic interface gave people the choice to refuse the connection I sent....now if I use the above they haven't that choice and I think that is wrong!!
bookie56
