Reposting this as requested by Admin (but with more explanation).
I am not getting the 'Commercial Use Suspected' Timeout
I have a few computers that I use TeamViewer one but this new problem only happens on a pair of Win10 PCs in one direction.
When I connect from my main PC into my second PC it seems to connect fine but the moment the window opens it closes with no error messages. On the second PC I get the usual pop-up 'thanks for playing fair and not breaking the rules etc' that you normally get when you close the connection.
I can connect from the main PC into the second PC using the TeamViewer online WebApp with no difficulties.
I can connect from second PC into the main PC using TeamViewer with no problems.
I can also use my main PC can connect to other remote PCs and RaspberryPi computers with no issues.
I have not changed anything on the main PC that should affect this.
I am only getting the issue in one direction and not when I connect to other machines or use the WebApp.
Does anyone have an idea what might be going wrong? Please help.
