Out of technical point I do know the difference between client and host.
My question my wish:
I would like to get a smart TV host software and would like to keep this host software version for a long time without a update.
We do have installed in parallel **Third Party Product** as a fallback access. We must enable specific routing for **Third Party Product** what is not secure and we use only that by a emergency problem, wenn TV has a update problem.
We do have sometimes a lot of troubles with the TV update process. Not each automatic update does work fine.
I would like to see a very small host subset installation, only to remote a PC with the function filetranster. The same as **Third Party Product** das offer.
e.g. This small subset function could be selected during installation.
