Hello everyone,
I use an iMac with macOS High Sierra installed.
The connections used to work fine, but recently teamviewer keeps crashing when I try to connect to a remote user, and can't connect anymore, it used to work very well but at some point, it started crashing.
I uninstalled the teamviewer, and tried to upgrade to the latest version but I can't install any version because of the version of the OS.
Can you please let me know which version of teamviewer works with high sierra and if I will be able to use teamviewer anymore with high sierra? It looks like the teamviewer team are blocking high sierra for use (at least this is what seems to happen).
