I seem to have an issue with multi-monitor support on Android. I have 3 4Kmonitors at 3840x2160 and 1 HD at 1920x1080 the HD one is typically turned off. Teamviewer detects the 4 monitors even if the HD one is turned off. That in itself is not an issue, but when I use the icon to switch between monitors on my Android device (Samsung used in DEX mode), everything is fine until I hit the 4th monitor. When I hit that monitor the app seems to resize everything to HD, and after that I can only see my other 3 monitors through a 1920 x 1080 view, which means I have to scroll all over the place and basically makes the use of teamviewer impossible. The immediate solution is of course to not switch to that HD screen, but given that the multi monitor button goes through each monitor one at a time, it doesn't make that easy, as as soon as I need to go to another monitor and come back I am basically out of luck.
Is there any other solution to this?
