Hi there,
Since upgrading to the new Teamviewer, I can no longer stretch my window across 2 monitors.
The remote monitor has a single ultrawide monitor 3840x1080. I used to be able to drag my TV window across my 2 monitors to replicate this width and see the full extent of the remote screen.
Now, I can still drag the window across both my monitors but the remote screen size stays the same and appears very small (doesn't scale with the size of the window):
Optimal resolution is set at 1920x1080 - If I set it to this, it shrinks down the width which is fine for viewing on a single monitor but I can't use the width like a dual screen to have a window open side by side.
Is there a way to keep the highest ultrawide resolution of the remote monitor and zoom it to fit the size of the window across my 2 monitors??
