I have started pushing out new TV Host via SCCM.. testing worked great. However what i have noticed is there is an issue with the 'Managers' section..
The Device Group for all new installs has Managers (lets call them MgrGrp1) with permissions to allow Easy Access.
I have a deployment which uses 'Assignment' that I have tried to not include default Managers (so the Device Group assigns access via inherit). But what i am finding is that when i install on a new device it wont allow easy access..
If i use the new web interface (because old one wont let me) to setup the access levels on all new devices via 'assignment (or Roll-out on new web interface)' it allows me to choose a User Group 'MgrGrp1' but wont allow me to choose what default settings i want it to have..
Why do devices which are installed via custom module, and assignment (or Roll-out on new web interface), not inherit the managers from the device group it is in?
This is a huge issue as I now need to reinstall on over 500 devices to have it select via the 'assignment' individuals instead of via inherit from the Device Group the device is located in..
Hope this all makes sense and you can get back to me with a fix as this now causes issues with remote management and access for users. Especially if you hide the temp password meaning the end user can't provide one.
