Hello
I'm connecting at work to different computers since 1 year. I'm using since the beginning my laptop to remote connect to them with a 4k screen and I'm also having a 2nd screen at 2k. Computers I'm connecting to are set to 2k or 4k. Everything was working fine since something like 3-4 weeks.
I'm now facing the problem when I'm connecting to another computer in 2k using my 4k screen the cursor is disappearing in certain region of the remote computer, particularly in field you can edit. On non editable parts of the screen I can see the cursor.
If I use the 2k screen or change my laptop screen to 2k it is working. I tried to update my graphic card drivers, no change.
This was perfectly working before. Any idea what could be the problem?
