My father is 94 years old and lives in another State. With TeamViewer 12, is it possible to connect to his computer WITHOUT any intervention on his part; i.e., a password or button press for confirmation? I used to be able to do this with TeamViewer 11 when he had Windows XP but now I am setting up a new computer for him with Windows 10 and TeamViewer 12 and cannot seem to remotely connect to his new computer without either a password or a button push for confirmation. I really need to connect to his computer without any intervention on his part. Thanks for your all's time and assistance! Dave
Hey,
have you looked at this instruction?https://www.teamviewer.com/en/res/pdf/first_steps_unattended_access_en.pdf
I know this is not for Teamviewer 12, but the settings should be the same. You have to set a personal password on the other computer, so you can access the computer without your partner having to do anything.
Open Teamviewer, then click on "Menu" and then on "Options". A windows should pop up. Now you have to click on "Securtiy".It should look like this:
You have to set a password for "unattend access". It will always stay the same and no interaction is needed. Also you should check the box "Start Teamviewer with Windows" under the "General" tab.
I hope this help :-)
Hey PastorDATM,
no problem, I'm glad i could help :smileyhappy:
Hi tarek13,
Thank you, thank you, thank you! You steered me in the right direction to finally figure out what I was doing wrong. Thanks again!!! Dave
No idea if it has to do with Win 10; on my site (Win7 Prof, TeamViewer 12) it works perfectly.
Regards, Thiersee
Hi Thiersee, we both already have TeamViewer 12. With TeamViewer 10 or 11 (I forget which version), I was able to set up remote access by just "clicking" on his computer link. No action was required on his part. But with TeamViewer 12, it seems he either has to confirm the connection or give the password to connect. Am I overlooking something? That is what I am trying to figure out. Thanks! Dave
https://www.teamviewer.com/en/download/windows/
Hi Thiersee, thanks for the reply but I was not able to find "TV Host" because Googling it brings up too many other hits. Can you provide a link? Also, I am actually looking for a way to do this within the TeamViewer app itself. Is that possible? Thanks for your time and assistance! Dave
Install TV Host on your father's computer giving a password and start with windows.
Your father will have only to switch on the PC.Regards, Thiersee
