When I insert the TeamViewer ID with the new interface with the num pad the program write the number but make also the function of the num pad without numlock active.
When I write for example "14" , after the 4 you see that the cursor move to left and after to right in about 1 secound, the problem is that when I write all the number at the end the number are mixed
