Hi
I've been unable to connect to my remote hosts since authentication issue on Oct 8, 2024
Checked my system log, and found the following error that seems to be relevant. Not sure if it is a server side issue. Or, if there's a change in connectivity configurations which causes block by router on my or user's end. Appreciate some insight. Thanks
2024/10/09 07:14:32.430 27641-27675 E/TeamViewer SslClient[0xb400007935b1b000]::CurlFinished(): Connect to https://hk-hkg-anx-r001.router.teamviewer.com:443/ failed with Failed to connect to hk-hkg-anx-r001.router.teamviewer.com port 443 after 6002 ms: Timeout was reached
2024/10/09 07:14:32.431 27641-27675 E/TeamViewer SecurePort443Connection[3]::ConnectInternal: Failed to connect error: generic:111
2024/10/09 07:14:32.432 27641-27675 E/TeamViewer CTcpConnectionBase[3]::HandleConnect(): Connect failed to dest-ip hk-hkg-anx-r001.router.teamviewer.com:443 with error 111 Connection refused
